[fdo][FDO147][Modified] SqlServer 2005: Defect 820804 (onstraint parsing failure on ...
Dan Stoica
dan.stoica at autodesk.com
Thu Aug 31 11:53:43 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO147
Type:
Defect
Artifact ID:
FDO147 (SqlServer 2005: Defect 820804 (onstraint parsing failure on SQL Server 2005))
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO147
Modified
File: trunk/Utilities/Common/FdoCommon.vcproj https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/FdoCommon.vcproj?view=diff&rev=335&p1=trunk/Utilities/Common/FdoCommon.vcproj&r1=334&p2=trunk/Utilities/Common/FdoCommon.vcproj&r2=335
File: trunk/Utilities/Common/Src/Parse/yyConstraint.y https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/Parse/yyConstraint.y?view=diff&rev=335&p1=trunk/Utilities/Common/Src/Parse/yyConstraint.y&r1=334&p2=trunk/Utilities/Common/Src/Parse/yyConstraint.y&r2=335
File: trunk/Utilities/Common/Src/Parse/yyConstraintWin.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/Parse/yyConstraintWin.cpp?view=diff&rev=335&p1=trunk/Utilities/Common/Src/Parse/yyConstraintWin.cpp&r1=334&p2=trunk/Utilities/Common/Src/Parse/yyConstraintWin.cpp&r2=335
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
