[fdo][FDO318][Modified] Fixed several defects; added new TestCommon static lib
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Fri Dec 1 09:18:48 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO318
Type:
Defect
Artifact ID:
FDO318 (Fixed several defects; added new TestCommon static lib)
Modified by:
Pierre Dalcourt
pierredalcourt (pierre.dalcourt at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO318 "Fixed several defects; added new TestCommon static library"
Modified
File: trunk/Providers/GenericRdbms/Nls/fdordbmsmsg.mc https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Nls/fdordbmsmsg.mc?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Nls/fdordbmsmsg.mc&r1=440&p2=trunk/Providers/GenericRdbms/Nls/fdordbmsmsg.mc&r2=441
File: trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/Makefile.am https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/Makefile.am?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/Makefile.am&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/Makefile.am&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/Pch.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/Pch.h?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/Pch.h&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/Pch.h&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Makefile.am https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Makefile.am?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Makefile.am&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Makefile.am&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/Makefile.am https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/Makefile.am?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/Makefile.am&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/Makefile.am&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/Makefile.am https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/Makefile.am?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/Makefile.am&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/Makefile.am&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcDescribeSchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcDescribeSchemaTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcDescribeSchemaTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcDescribeSchemaTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.h?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.h&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.h&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestMySql.vcproj https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestMySql.vcproj?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestMySql.vcproj&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestMySql.vcproj&r2=441
File: trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestOdbc.vcproj https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestOdbc.vcproj?view=diff&rev=441&p1=trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestOdbc.vcproj&r1=440&p2=trunk/Providers/GenericRdbms/Src/UnitTest/UnitTestOdbc.vcproj&r2=441
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
