[fdo][FDO321][New] SHP: corrupted spatial index (.IDX) file not regenerated
Dan Stoica dan.stoica at autodesk.com
Fri Dec 1 10:10:32 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO321
Type
 Defect
Artifact ID
 FDO321 (SHP: corrupted spatial index (.IDX) file not regenerated)
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Description set to new value
  There are cases of corrupted .IDX when its header indicates 0 (zero) features although the .SHP file contains not NULL geometries. The .IDX file should be programatically regenerated to avoid a manual file delete.
- Artifact created
- Artifact Status set to new value
  New
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
