[fdo][FDO324][Modified] SHP provider: merge Artifacts FDO210, FDO320, FDO321, FDO312...
Dan Stoica
dan.stoica at autodesk.com
Fri Dec 1 11:12:05 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO324
Type:
Defect
Artifact ID:
FDO324 (SHP provider: merge Artifacts FDO210, FDO320, FDO321, FDO312 from branch 3.2 to trunk)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO324
Modified
File: trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp?view=diff&rev=571&p1=trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp&r1=570&p2=trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp&r2=571
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
