[fdo][FDO326][New] Support updating constraints when RDBMS uses different name ...
Brent Robinson brent.robinson at autodesk.com
Fri Dec 1 15:45:01 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO326
Type
 Enhancement
Artifact ID
 FDO326 (Support updating constraints when RDBMS uses different name in DDL operation)
Reported by
 Brent Robinson
 brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Priority set to new value
  P1
- Summary set to new value
- Artifact created
- Target milestone set to new value
  3.2.1
- Description set to new value
  Currently, when the GenericRdbms providers generate SQL statements for updating or deleting constraints, the statements refer to the constraint by name. However, for some RDBMS's (.e.g. for OWM-enabled Oracle tables) the constraint must be named slightly differently in the SQL statement.
This enhancement allows provider-specific Schema Manager implemenations to override the name of the constraint that goes into these SQL statements.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
