[fdo][FDO313][Modified] Multithreading issues cleanup
Jack Lee jack.lee at autodesk.com
Fri Dec 1 16:31:35 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO313
Type:
Defect
Artifact ID:
FDO313 (Multithreading issues cleanup)
Modified by:
Jack Lee
jacklee (jack.lee at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO313 - Don't ref count the global strings
Modified
File: branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Xml.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Xml.cpp?view=diff&rev=572&p1=branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Xml.cpp&r1=571&p2=branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Xml.cpp&r2=572
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
