[fdo][FDO326][Modified] Support updating constraints when RDBMS uses different name ...
Brent Robinson brent.robinson at autodesk.com
Tue Dec 5 12:28:23 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO326
Type:
Enhancement
Artifact ID:
FDO326 (Support updating constraints when RDBMS uses different name in DDL operation)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
On updating constraints, handle RDBMS's where constraint name in DDL statements differs from actual constraint name.
Added a mechanism for a provider to override the constraint name used in an update constraint statement.
-- Submission Reviewed set to new value:
Yes
-- Enhancement Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
