[fdo][FDO335][New] ODBC: Cannot perform two consecutive commands w/Oracle
Gavin Cramer
gavin.cramer at autodesk.com
Wed Dec 6 14:44:01 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO335
Type
Defect
Artifact ID
FDO335 (ODBC: Cannot perform two consecutive commands w/Oracle)
Reported by
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Summary set to new value
- Artifact created
- Description set to new value
This fixes a problem with ODBC's reading of tables from an Oracle database. The root cause is a defect in ODBC itself with re-executed queries that have bond variables. The workaround is to suppress the use of static cursors in this query. This will slightly degrade performance of schema loading when a configuration is set on the FDO connection -- though the main improvements from FDO217 remain.
A missing check for FDO metaschema was also added to the Schema Manager.
- Defect Severity set to new value
Medium
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
