[fdo][FDO326][Modified] Support updating constraints when RDBMS uses different name ...
Brent Robinson
brent.robinson at autodesk.com
Wed Dec 6 16:44:07 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO326
Type:
Enhancement
Artifact ID:
FDO326 (Support updating constraints when RDBMS uses different name in DDL operation)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO326: Fixed constraint column order problem.
Modified
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp?view=diff&rev=483&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp&r1=482&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp&r2=483
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
