[fdo][FDO340][New] insert fails with 0 property values
Barbara Zoladek
barbara.zoladek at autodesk.com
Tue Dec 12 15:32:58 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO340
Type
Defect
Artifact ID
FDO340 (insert fails with 0 property values)
Reported by
Barbara Zoladek
barbarazoladek (barbara.zoladek at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
1) Create (or find) an FdoClass that has only 1 proerty (the identtiy property)
2) Create an isnert command, point it to the above FdoClass, do not populate its FdoPropertyValueCollection, and Execute it
EXPECTED RESULT: a row is inserted in the datastore
ACTUAL RESULT: a row is not inserted in the datastore, and a NULL identiy FdoFeatureReader is returned by the FdoISelect::Execute() method.
- Artifact Status set to new value
New
- Defect Severity set to new value
Medium
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
