[fdo][FDO341][New] MySql Provider is ignoring 'auto increment' flag on properti...
Dan Stoica
dan.stoica at autodesk.com
Wed Dec 13 15:15:16 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO341
Type
Defect
Artifact ID
FDO341 (MySql Provider is ignoring 'auto increment' flag on properties)
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Description set to new value
A column in MySql may have AUTO_INCREMENT flag set. MySqlProvider interpretes it correctly only for BIGINT column types.
- Steps to Reproduce set to new value
a) create time: In case the property type is Int32 or Int16 the 'autoincrement' flag is ignored.
b) at read time: although the column has AUTO_INCREMENT flag, it is reversed engineered as a property with autoincrement=false'. This is in case of int columns.
- Artifact created
- Summary set to new value
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
