[fdo][FDO342][New] SDF: Allow update of existing property constraints
Brent Robinson
brent.robinson at autodesk.com
Wed Dec 13 16:14:04 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO342
Type
Defect
Artifact ID
FDO342 (SDF: Allow update of existing property constraints)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Target milestone set to new value
3.2.1
- Artifact created
- Component set to new value
SDF
- Platform set to new value
All
- Operating system set to new value
All
- Summary set to new value
- Artifact Status set to new value
New
- Description set to new value
Currently, the SDF Provider does not allow existing property constraints to be modified or constraints to be added or removed to or from existing properties.
This change lifts this restriction for the following cases:
- the property's class has no objects.
- a constraint is being add or an existing
constraint is being made less restrictive.
Consequently, the following will still be disallowed when the property's class has objects:
- add a constraint to a property that has no
constraint
- make the constraint more restrictive.
- Subcomponent set to new value
SCHEMA
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
