[fdo][FDO342][Modified] SDF: Allow update of existing property constraints
Brent Robinson
brent.robinson at autodesk.com
Fri Dec 15 13:02:43 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO342
Type:
Defect
Artifact ID:
FDO342 (SDF: Allow update of existing property constraints)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO342: Support updating SDF constraints.
Added
File: branches/3.2.x/Fdo/Unmanaged/Inc/Common/Compare.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Inc/Common/Compare.h?view=auto&rev=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.cpp?view=auto&rev=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.h?view=auto&rev=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.cpp?view=auto&rev=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.h?view=auto&rev=596
Modified
File: branches/3.2.x/Fdo/Unmanaged/Common.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Common.vcproj?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Common.vcproj&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Common.vcproj&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Inc/FdoCommon.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Inc/FdoCommon.h?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Inc/FdoCommon.h&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Inc/FdoCommon.h&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Inc/Makefile.am https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Inc/Makefile.am?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Inc/Makefile.am&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Inc/Makefile.am&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r2=596
File: branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc?view=diff&rev=596&p1=branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc&r1=595&p2=branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc&r2=596
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
