[fdo][FDO342][Modified] SDF: Allow update of existing property constraints
Brent Robinson brent.robinson at autodesk.com
Fri Dec 15 13:43:58 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO342
Type:
Defect
Artifact ID:
FDO342 (SDF: Allow update of existing property constraints)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO342: Fixed Internal.cpp name ambiguity.
Added
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.cpp?view=auto&rev=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.h?view=auto&rev=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaInternal.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaInternal.cpp?view=auto&rev=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaInternal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaInternal.h?view=auto&rev=599
Modified
File: branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Makefile.am&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r2=599
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp?view=diff&rev=599&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r1=598&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r2=599
Removed
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.cpp?view=auto&rev=598
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Expression/Internal.h?view=auto&rev=598
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.cpp?view=auto&rev=598
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/Internal.h?view=auto&rev=598
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
