[fdo][FDO350][New] Geometry: shares objects between threads
Gavin Cramer
gavin.cramer at autodesk.com
Mon Dec 18 15:52:59 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO350
Type
Defect
Artifact ID
FDO350 (Geometry: shares objects between threads)
Reported by
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Description set to new value
This fixes the FdoGeometry's to avoid sharing (via ref-counting) objects that its factory returns with its internal object pool. This is to make sure that geometries are thread-safe - a client might pass an instantiated object between threads, assuming that the geometry was not shared.
This as already being done for FGF-bearing byte arrays.
- Summary set to new value
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
