[fdo][FDO351][New] GenericRdbms: ApplySchema alters pre-existing views.
Brent Robinson
brent.robinson at autodesk.com
Tue Dec 19 11:10:09 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO351
Type
Defect
Artifact ID
FDO351 (GenericRdbms: ApplySchema alters pre-existing views.)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Artifact created
- Operating system set to new value
All
- Component set to new value
RDBMS
- Artifact Status set to new value
New
- Subcomponent set to new value
SCHEMA
- Platform set to new value
All
- Priority set to new value
P2
- Description set to new value
Through the use of Schema Overrides, it is possible to map a class definition to a pre-existing view in an FDO-enabled datastore.
However, when this is done, ApplySchema tries to add system property columns to the view. It attempts to drop and re-create the view with the new columns. However, the Schema Manager does not track the underlying selects for these views so the re-create fails. This effectively drops the view.
- Summary set to new value
- Steps to Reproduce set to new value
- created an FDO-enabled datastore.
- created the following table:
create table parceltable (
featureid decimal(20) not null,
parcelkey varchar(256),
primary key (featureid)
- created the following view:
create view myparcel as select * from parceltable;
- create a feature schema and override set. The schema contains a single feature class. The override set maps the feature class ontp the view.
- perform an ApplySchema from the schema and overrides.
- Version set to new value
V2
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
