[fdo][FDO351][Modified] GenericRdbms: ApplySchema alters pre-existing views.
Brent Robinson brent.robinson at autodesk.com
Tue Dec 19 11:50:16 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO351
Type:
Defect
Artifact ID:
FDO351 (GenericRdbms: ApplySchema alters pre-existing views.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO351: ported from 3.2.x branch.
Modified
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ObjectPropertyClass.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ObjectPropertyClass.cpp?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ObjectPropertyClass.cpp&r1=591&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ObjectPropertyClass.cpp&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3_master.txt&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_defout1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_defout1_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_defout1_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_defout1_master.txt&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt&r2=592
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt?view=diff&rev=592&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt&r1=591&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt&r2=592
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
