[fdo][FDO355][New] SHP provider needs to handle the Language Driver ID (LDID)
    Dan Stoica
    dan.stoica at autodesk.com
    Wed Dec 20 15:42:39 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO355
Type
 Defect
Artifact ID
 FDO355 (SHP provider needs to handle the Language Driver ID (LDID))
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Artifact created
- Description set to new value
  Currently a DBF file needs a .CPG file containing a valid code page in order for strings to display correctly in different locales. This is not always necessay since the DBF header may store the LDID which can be mapped to a code page.
An approach consistent with ArcPad 9 would be:
- read the DBF header. in case the LDID is valid then map to a documented code page
- in case the LDID is not valid, read the code page from the .CPG if any.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
