[fdo][FDO99][New] Fixed SHP unit test failures on Linux (non_ascii_class_name*...
Romica Dascalescu
romica.dascalescu at autodesk.com
Wed Jul 26 16:53:40 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO99
Type
Task
Artifact ID
FDO99 (Fixed SHP unit test failures on Linux (non_ascii_class_name*))
Reported by
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Artifact created
- Testing Notes set to new value
Rebuild Granite on Fedora Core3 & Fedora Core4.
Run the unit testes from command line and from crontab.
- Artifact Status set to new value
New
- Developer Notes set to new value
This change affect only Linux platform.
- Need By Date set to new value
2006-07-26
- Summary set to new value
- Task Priority set to new value
Medium
- Description set to new value
Added two new macros used to convert a wide character string into a utf8 string.
Modified FdoCommonFile class to use only utf8 strings when tries to access the files.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
