[fdo][FDO101][New] Implemented a Linux & Windows script to test the OpenSource ...
Romica Dascalescu
romica.dascalescu at autodesk.com
Thu Jul 27 13:09:03 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO101
Type
Task
Artifact ID
FDO101 (Implemented a Linux & Windows script to test the OpenSource build)
Reported by
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Need By Date set to new value
2006-07-27
- Artifact created
- Summary set to new value
- Description set to new value
Implemented a Linux & Windows script to test the OpenSource build which will be run daily/weekly.
The scripts need as parameter the location of fdocore tar files and a file (release.txt) which contains build number (or the build number can be provided using option -b).
- Artifact Status set to new value
New
- Submission Reviewed set to new value
Yes
- Task Priority set to new value
Medium
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
