[fdo][FDO104][New] Add SHP Managed UnitTests to fdoshp.osgeo.org
Greg Boone greg.boone at autodesk.com
Fri Jul 28 15:44:03 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO104
Type
 Task
Artifact ID
 FDO104 (Add SHP Managed UnitTests to fdoshp.osgeo.org)
Reported by
 Greg Boone
 gregboone (greg.boone at autodesk.com)
New artifact details:
- Target milestone set to new value
  3.2.0
- Priority set to new value
  P3
- Description set to new value
  Add the Autodesk Managed SHP UnitTests to the fdoshp.osgeo.org SubVersion. This will allow users to see how Managed FDO code is executed.
- Task Priority set to new value
  High
- Planned Start Date set to new value
  2006-07-28
- Need By Date set to new value
  2006-07-28
- Artifact Status set to new value
  New
- Summary set to new value
- Artifact created
- Progress Notes set to new value
  NOTES: Several UnitTest files need additional work to pass all tests. The tests that are failing have been removed from the UnitTest temporarily.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
