[fdo][FDO105][New] DescribeSchema memory leak (Physical Schema Manager)
Brent Robinson
brent.robinson at autodesk.com
Fri Jul 28 16:06:21 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO105
Type
Defect
Artifact ID
FDO105 (DescribeSchema memory leak (Physical Schema Manager))
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Version set to new value
V1
- Description set to new value
When a DescribeSchema command is executed and then the current connection is closed, the Physical Schema Manager (FdoSmPhMgr) is not released. Therefore, it and all of its subordinate objects are leaked.
- Summary set to new value
- Operating system set to new value
All
- Component set to new value
RDBMS
- Artifact Status set to new value
New
- Target milestone set to new value
3.2.0
- Subcomponent set to new value
SCHEMA
- Platform set to new value
All
- Defect Severity set to new value
Medium
- Priority set to new value
P3
- Steps to Reproduce set to new value
- connect to a MySQL datastore
- execute a DescribeSchema command
(or any Feature Command. These do a
DescribeSchema internally).
- close the connection.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
