[fdo][FDO105][Modified] DescribeSchema memory leak (Physical Schema Manager)
Brent Robinson brent.robinson at autodesk.com
Fri Jul 28 16:11:50 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO105
Type:
Defect
Artifact ID:
FDO105 (DescribeSchema memory leak (Physical Schema Manager))
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Defect Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Changed backpointer, from FdoSmPhColumnList to FdoSmPhMgr, to not hold a reference. This breaks a circular reference, allowing FdoSmPhMgr to be released on disconnect.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
