[fdo][FDO100][Modified] Defect 750920: FdoXmlFeatureSerialize.XMLSerialize() causes ...
Brent Robinson
brent.robinson at autodesk.com
Mon Jul 31 08:06:47 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO100
Type:
Defect
Artifact ID:
FDO100 (Defect 750920: FdoXmlFeatureSerialize.XMLSerialize() causes Bad parameter to method exception)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO100
Modified
File: trunk/Fdo/UnitTest/GmlWriteTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/GmlWriteTest.cpp?view=diff&rev=298&p1=trunk/Fdo/UnitTest/GmlWriteTest.cpp&r1=297&p2=trunk/Fdo/UnitTest/GmlWriteTest.cpp&r2=298
File: trunk/Fdo/UnitTest/gml_write_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/gml_write_master.txt?view=diff&rev=298&p1=trunk/Fdo/UnitTest/gml_write_master.txt&r1=297&p2=trunk/Fdo/UnitTest/gml_write_master.txt&r2=298
File: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h?view=diff&rev=298&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h&r1=297&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h&r2=298
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureSerializer.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureSerializer.cpp?view=diff&rev=298&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureSerializer.cpp&r1=297&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureSerializer.cpp&r2=298
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureWriter.cpp?view=diff&rev=298&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureWriter.cpp&r1=297&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureWriter.cpp&r2=298
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
