[fdo][FDO106][Modified] Add Managed UnitTests to fdo.osgeo.org
Greg Boone
greg.boone at autodesk.com
Mon Jul 31 10:05:41 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO106
Type:
Task
Artifact ID:
FDO106 (Add Managed UnitTests to fdo.osgeo.org)
Modified by:
Greg Boone
gregboone (greg.boone at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO106: Add Managed UnitTests to fdo.osgeo.org
Added
Directory: trunk/Fdo/Managed/UnitTest
File: trunk/Fdo/Managed/UnitTest/Common.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/Common.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/EntryPoint.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/EntryPoint.cs?view=auto&rev=299
Directory: trunk/Fdo/Managed/UnitTest/Properties
File: trunk/Fdo/Managed/UnitTest/Properties/AssemblyInfo.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/Properties/AssemblyInfo.cs?view=auto&rev=299
Directory: trunk/Fdo/Managed/UnitTest/TestFiles
File: trunk/Fdo/Managed/UnitTest/TestFiles/g_coords.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/g_coords.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob_hex.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob_hex.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob_hex_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob_hex_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_blob_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_inherited_feature_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_inherited_feature_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_multi_geometry.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_multi_geometry.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_multi_geometry_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_multi_geometry_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_collection.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_collection.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_feature.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_feature.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_geometry.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_geometry.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_geometry_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_geometry_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_object.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_object.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_object_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_nested_object_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_feature.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_feature.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_feature_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_feature_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_geometry.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_geometry.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_geometry_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_geometry_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_object.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_object.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_object_schema.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_simple_object_schema.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/gml_write_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/gml_write_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc1a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc1a_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc1b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc1b_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc2a_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc2b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc2b_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc_err1a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc_err1a_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc_err1b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc_err1b_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc_error.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc_error.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/sc_v2.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/sc_v2.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_all1_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_all1_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_all_v2.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_all_v2.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_all_v2_out_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_all_v2_out_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext1.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext1.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext1b.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext1b.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext_a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext_a_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext_b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext_b_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext_c_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ext_c_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_mappings_212_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_mappings_212_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge1a.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge1a.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge1b.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge1b.xml?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge2a_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge2b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge2b_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge_err_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_merge_err_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ref_err1_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ref_err1_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_ref_err2_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_ref_err2_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs1a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs1a_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs1b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs1b_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs1c_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs1c_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs2_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs2_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs_err_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_refs_err_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_uns_high_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_uns_high_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_uns_low_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_uns_low_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_uns_norm_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_uns_norm_master.txt?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/TestFiles/schema_unsupported.xsd https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/TestFiles/schema_unsupported.xsd?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/UnitTest.csproj https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/UnitTest.csproj?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/UnitTest.sln https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/UnitTest.sln?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgCapabilitiesTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgCapabilitiesTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgClientServicesTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgClientServicesTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgCommandTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgCommandTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgCommonTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgCommonTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgCounter.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgCounter.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgExpressionParseTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgExpressionParseTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgExpressionTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgExpressionTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgExtractor.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgExtractor.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgFilterParseTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgFilterParseTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgFilterTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgFilterTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgGeometryMemPerfTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgGeometryMemPerfTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgGeometryTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgGeometryTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgGmlTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgGmlTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgIoTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgIoTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgNester.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgNester.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgSpatialContextTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgSpatialContextTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgSpatialUtilityTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgSpatialUtilityTest.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgStringStream.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgStringStream.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgUnitTestProcessor.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgUnitTestProcessor.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgUnitTestUtil.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgUnitTestUtil.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgXmlFormatter.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgXmlFormatter.cs?view=auto&rev=299
File: trunk/Fdo/Managed/UnitTest/mgXmlTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgXmlTest.cs?view=auto&rev=299
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
