[fdo][FDO241][Modified] Second constraint lost when deserializing class with 2 uniqu...
Brent Robinson
brent.robinson at autodesk.com
Wed Nov 1 08:01:58 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO241
Type:
Defect
Artifact ID:
FDO241 (Second constraint lost when deserializing class with 2 unique constraints from XML.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO241
Modified
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp?view=diff&rev=296&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp&r1=295&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp&r2=296
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt?view=diff&rev=296&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt&r1=295&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt&r2=296
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt?view=diff&rev=296&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt&r1=295&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt&r2=296
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt?view=diff&rev=296&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt&r1=295&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt&r2=296
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
