[fdo][FDO241][Modified] Second constraint lost when deserializing class with 2 uniqu...
    Brent Robinson
    brent.robinson at autodesk.com
    Wed Nov  1 08:31:57 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO241
Type:
Defect
Artifact ID:
FDO241 (Second constraint lost when deserializing class with 2 unique constraints from XML.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO241: merged from branch 3.2.x
Modified
File: trunk/Fdo/UnitTest/SchemaTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/SchemaTest.cpp?view=diff&rev=486&p1=trunk/Fdo/UnitTest/SchemaTest.cpp&r1=485&p2=trunk/Fdo/UnitTest/SchemaTest.cpp&r2=486
File: trunk/Fdo/UnitTest/schema_all1_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all1_master.txt?view=diff&rev=486&p1=trunk/Fdo/UnitTest/schema_all1_master.txt&r1=485&p2=trunk/Fdo/UnitTest/schema_all1_master.txt&r2=486
File: trunk/Fdo/UnitTest/schema_merge1a.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge1a.xml?view=diff&rev=486&p1=trunk/Fdo/UnitTest/schema_merge1a.xml&r1=485&p2=trunk/Fdo/UnitTest/schema_merge1a.xml&r2=486
File: trunk/Fdo/UnitTest/schema_merge2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge2a_master.txt?view=diff&rev=486&p1=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r1=485&p2=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r2=486
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
