[fdo][FDO241][Modified] Second constraint lost when deserializing class with 2 uniqu...
Brent Robinson
brent.robinson at autodesk.com
Wed Nov 1 08:42:00 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO241
Type:
Defect
Artifact ID:
FDO241 (Second constraint lost when deserializing class with 2 unique constraints from XML.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
In fdo\Schema\MergeContext.cpp, added property names to the key for unique constraint reference collection elemenents. This allows multiple unique constraints per class to be handled.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Defect Resolution set to new value:
Submitted
-- Submission Reviewed set to new value:
Yes
-- Target milestone set to new value:
3.2.1
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
