[fdo][FDO246][Modified] MySQL - value returned from a query for FdoDataType_Byte doe...
Brent Robinson brent.robinson at autodesk.com
Thu Nov 2 13:17:44 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO246
Type:
Defect
Artifact ID:
FDO246 (MySQL - value returned from a query for FdoDataType_Byte does not match value inserted)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Defect Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Modified the MySQL and ODBC RDBMS drivers to map tinyint column types to the RDBI_SHORT type
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Submission Reviewed set to new value:
Yes
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
