[fdo][FDO247][New] SDF scrollable reader initialization can be optimized when n...
Badreddine Karoui
badreddine.karoui at autodesk.com
Thu Nov 2 17:10:07 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO247
Type
Defect
Artifact ID
FDO247 (SDF scrollable reader initialization can be optimized when no filter is provided)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Artifact created
- Priority set to new value
P2
- Artifact Status set to new value
New
- Summary set to new value
- Subcomponent set to new value
FEATURE COMMANDS
- Description set to new value
In the case where no filter or ordering is required, the initialization of the scrollable reader can be much faster if the sdf index table is used instead of the data table.
- Defect Severity set to new value
Medium
- Component set to new value
SDF
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
