[fdo][FDO248][New] Get NULL message when attempting to sort SHP data in column ...
Dan Stoica
dan.stoica at autodesk.com
Thu Nov 2 17:32:54 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO248
Type
Defect
Artifact ID
FDO248 (Get NULL message when attempting to sort SHP data in column with empty fields linked)
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
Run ExtendedSelect command against a SHP file containing Prop1 with some null values. Add Prop1 to the ordering collection.
Exceute will fail with the message:
The property 'Prop1' is NULL
- Artifact created
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
