[fdo][FDO254][New] Missing schema read example in Developer's Guide
Mateusz Loskot mateusz at loskot.net
Sun Nov 5 14:48:00 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO254
Type
 Defect
Artifact ID
 FDO254 (Missing schema read example in Developer's Guide)
Reported by
 Mateusz Loskot
 mloskot (mateusz at loskot.net)
New artifact details:
- Description set to new value
  In the Developer's Guide, on page 66, Chapter 7 "Schema Management" describe schema example is mentioned:
"The example in the following link is a simple function that shows how to use FdoIDescribeSchema and loop through the schema and class containers to search for duplicate class names.
For a schema description example, see Example: Describing a Schema and Writing It to an XML File (page 88)."
The example that is refered here, about how to "loop through the schema and class containers" is missing.
- Defect Severity set to new value
  Low
- Artifact created
- Component set to new value
- Operating system set to new value
  Linux
- Platform set to new value
  PC
- Summary set to new value
- OS Distribution and Version set to new value
  Ubuntu 6.06
- Artifact Status set to new value
  Unconfirmed
- Steps to Reproduce set to new value
  Check page 66 of the Dev Guide.
- Subcomponent set to new value
  DOCUMENTATION
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
