[fdo][FDO261][New] Oracle: Fix 837057 Oracle geometry performance
Gavin Cramer
gavin.cramer at autodesk.com
Mon Nov 6 10:24:12 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO261
Type
Defect
Artifact ID
FDO261 (Oracle: Fix 837057 Oracle geometry performance)
Reported by
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Artifact created
- Summary set to new value
- Description set to new value
Changed some functions in GDBI to allow higher performance transferring geometry values (currently only used by Oracle Provider).
Changed some project settings (in Debug mode) to be compatible with IBM Rational Purify 7.0.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
