[fdo][FDO262][Modified] FDO: Fix 837057 Oracle geometry performance
Gavin Cramer
gavin.cramer at autodesk.com
Mon Nov 6 15:12:14 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO262
Type:
Defect
Artifact ID:
FDO262 (FDO: Fix 837057 Oracle geometry performance)
Modified by:
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO262
Modified
File: branches/3.2.x/Fdo/Unmanaged/Common.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Common.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/Common.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/Common.vcproj&r2=493
File: branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r2=493
File: branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj&r2=493
File: branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj&r2=493
File: branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj&r2=493
File: branches/3.2.x/Fdo/Unmanaged/Nls.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Nls.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/Nls.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/Nls.vcproj&r2=493
File: branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj?view=diff&rev=493&p1=branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj&r1=492&p2=branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj&r2=493
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
