[fdo][FDO266][Modified] Fixed 767628.01 BC: cannot Insert data from WFS
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Nov 7 15:47:58 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO266
Type:
Defect
Artifact ID:
FDO266 (Fixed 767628.01 BC: cannot Insert data from WFS)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO266
Modified
File: branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h?view=diff&rev=496&p1=branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h&r1=495&p2=branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h&r2=496
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h?view=diff&rev=496&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r1=495&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r2=496
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt?view=diff&rev=496&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r1=495&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r2=496
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Deserializable.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Deserializable.cpp?view=diff&rev=496&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Deserializable.cpp&r1=495&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Deserializable.cpp&r2=496
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Flags.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Flags.cpp?view=diff&rev=496&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Flags.cpp&r1=495&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/Flags.cpp&r2=496
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
