[fdo][FDO274][New] SDF scrollable reader sorting does not work for double byte ...
Badreddine Karoui badreddine.karoui at autodesk.com
Wed Nov 8 17:23:20 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO274
Type
 Defect
Artifact ID
 FDO274 (SDF scrollable reader sorting does not work for double byte characters)
Reported by
 Badreddine Karoui
 badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Component set to new value
  SDF
- Priority set to new value
  P2
- Defect Severity set to new value
  Medium
- Artifact Status set to new value
  New
- Description set to new value
  The sort feature of the scrollable reader uses wcscmp to compare strings. It should use the collation aware function wcscoll instead.
- Summary set to new value
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
