[fdo][FDO284][New] WMS: Can't execute query to some WMS layers in server "http:...
Greg Boone
greg.boone at autodesk.com
Wed Nov 15 17:08:06 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO284
Type
Defect
Artifact ID
FDO284 (WMS: Can't execute query to some WMS layers in server "http://142.176.62.108/cgi-bin/mapserv.exe?map=D:\ms441oci\maps\NS_TOPO_5000.map")
Reported by
Greg Boone
gregboone (greg.boone at autodesk.com)
New artifact details:
- Target milestone set to new value
3.2.0
- Priority set to new value
P3
- Artifact created
- Artifact Status set to new value
New
- Defect Severity set to new value
Medium
- Subcomponent set to new value
CONNECTIONS
- Platform set to new value
All
- Component set to new value
WMS
- Description set to new value
1. Create a connection to WMS server http://142.176.62.108/cgi-bin/mapserv.exe?map=D:\ms441oci\maps\NS_TOPO_5000.map
2. Create a FdoISelect command
3. Execute query on layer "NS_TOPO_5000.5K_DL_Line". Don't use resample function.
Result: An exception is thrown. Error message is as follows.
"msWMSLoadGetMapParams(): WMS server error. Image size out of range, WIDTH and HEIGHT must be between 1 and 2048 pixels."
Expected: Query is executed successfully.
- Submission Reviewed set to new value
Yes
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
