[fdo][FDO285][New] Flush and synch data one class at a time
Badreddine Karoui badreddine.karoui at autodesk.com
Wed Nov 15 17:12:57 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO285
Type
 Defect
Artifact ID
 FDO285 (Flush and synch data one class at a time)
Reported by
 Badreddine Karoui
 badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
  This change is required to flush all the data of a given class(data,key and RTree table) before moving to the next class. Currently it flushes all the data tables then the key and then the rtree for all the classes.
Also use the low level transaction to group the above flushes per class.
- Component set to new value
  SDF
- Artifact Status set to new value
  New
- Summary set to new value
- Priority set to new value
  P3
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
