[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu
romica.dascalescu at autodesk.com
Thu Nov 16 13:10:22 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170 - Fix memory leaks in the ODBC provider (Fixed unit test)
Modified
File: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp?view=diff&rev=330&p1=branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp&r1=329&p2=branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp&r2=330
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
