[fdo][FDO291][New] Fixed: Fail to create MySQL data store when MySql provider i...
Romica Dascalescu
romica.dascalescu at autodesk.com
Mon Nov 20 10:49:52 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO291
Type
Defect
Artifact ID
FDO291 (Fixed: Fail to create MySQL data store when MySql provider is installed under a folder with double byte characters)
Reported by
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Summary set to new value
- Defect Severity set to new value
Medium
- Artifact created
- Description set to new value
Windows: using _wfopen(Unicode path) when SQL script files are opened.
Linux: using fopen(UTF-8 path) when SQL script files are opened.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
