[fdo][FDO291][Modified] Fixed: Fail to create MySQL data store when MySql provider i...
Romica Dascalescu romica.dascalescu at autodesk.com
Mon Nov 20 12:46:45 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO291
Type:
Defect
Artifact ID:
FDO291 (Fixed: Fail to create MySQL data store when MySql provider is installed under a folder with double byte characters)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO291 - Fixed: Fail to create MySQL data store when MySql provider is installed under a folder with double byte characters
Modified
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp?view=diff&rev=516&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r1=515&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r2=516
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp?view=diff&rev=516&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp&r1=515&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp&r2=516
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
