[fdo][FDO290][Modified] Constraint values - various boundary conditions
Brent Robinson brent.robinson at autodesk.com
Mon Nov 20 14:10:10 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO290
Type:
Defect
Artifact ID:
FDO290 (Constraint values - various boundary conditions)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO290 - Merged from 3.2.x branch
Modified
File: trunk/Fdo/UnitTest/CommonTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/CommonTest.cpp?view=diff&rev=517&p1=trunk/Fdo/UnitTest/CommonTest.cpp&r1=516&p2=trunk/Fdo/UnitTest/CommonTest.cpp&r2=517
File: trunk/Fdo/UnitTest/ExpressionParseTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/ExpressionParseTest.cpp?view=diff&rev=517&p1=trunk/Fdo/UnitTest/ExpressionParseTest.cpp&r1=516&p2=trunk/Fdo/UnitTest/ExpressionParseTest.cpp&r2=517
File: trunk/Fdo/UnitTest/ExpressionParseTest.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/ExpressionParseTest.h?view=diff&rev=517&p1=trunk/Fdo/UnitTest/ExpressionParseTest.h&r1=516&p2=trunk/Fdo/UnitTest/ExpressionParseTest.h&r2=517
File: trunk/Fdo/UnitTest/FilterParseTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/FilterParseTest.cpp?view=diff&rev=517&p1=trunk/Fdo/UnitTest/FilterParseTest.cpp&r1=516&p2=trunk/Fdo/UnitTest/FilterParseTest.cpp&r2=517
File: trunk/Fdo/UnitTest/FilterParseTest.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/FilterParseTest.h?view=diff&rev=517&p1=trunk/Fdo/UnitTest/FilterParseTest.h&r1=516&p2=trunk/Fdo/UnitTest/FilterParseTest.h&r2=517
File: trunk/Fdo/UnitTest/SchemaTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/SchemaTest.cpp?view=diff&rev=517&p1=trunk/Fdo/UnitTest/SchemaTest.cpp&r1=516&p2=trunk/Fdo/UnitTest/SchemaTest.cpp&r2=517
File: trunk/Fdo/UnitTest/schema_all1_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all1_master.txt?view=diff&rev=517&p1=trunk/Fdo/UnitTest/schema_all1_master.txt&r1=516&p2=trunk/Fdo/UnitTest/schema_all1_master.txt&r2=517
File: trunk/Fdo/UnitTest/schema_merge1a.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge1a.xml?view=diff&rev=517&p1=trunk/Fdo/UnitTest/schema_merge1a.xml&r1=516&p2=trunk/Fdo/UnitTest/schema_merge1a.xml&r2=517
File: trunk/Fdo/UnitTest/schema_merge2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge2a_master.txt?view=diff&rev=517&p1=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r1=516&p2=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r2=517
File: trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h&r1=516&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h&r2=517
File: trunk/Fdo/Unmanaged/Src/Common/StringP.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Common/StringP.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Common/StringP.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Common/StringP.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/Lex.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/Lex.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/Lex.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/Lex.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/Parse.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/Parse.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/Parse.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/Parse.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.h?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.h&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.h&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.y https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.y?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.y&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpression.y&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.h?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.h&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyExpressionWin.h&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.h?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.h&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.h&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.y https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.y?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.y&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilter.y&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.h?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.h&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Parse/yyFilterWin.h&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp&r2=517
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp?view=diff&rev=517&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r1=516&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r2=517
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
