[fdo][FDO292][New] WMS: DescribeSchemaMapping returns NULL when no configuratio...
Greg Boone
greg.boone at autodesk.com
Mon Nov 20 17:50:21 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO292
Type
Defect
Artifact ID
FDO292 (WMS: DescribeSchemaMapping returns NULL when no configuration file is set for the connection)
Reported by
Greg Boone
gregboone (greg.boone at autodesk.com)
New artifact details:
- Target milestone set to new value
3.2.0
- Operating system set to new value
All
- Subcomponent set to new value
CONNECTIONS
- Description set to new value
In WMS provider, when no configuration file is set for the connection, FdoWmsDescribeSchemaMapping::Execute will return NULL..
The correct behavior is to return the schema mappings that the WMS provider generate internally as default schema mappings for the default logical schema.
- Component set to new value
WMS
- Priority set to new value
P3
- Summary set to new value
- Submission Reviewed set to new value
Yes
- Artifact Status set to new value
New
- Defect Severity set to new value
Low
- Platform set to new value
All
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
