[fdo][FDO293][New] WFS/WMS: Localize error messages
Greg Boone greg.boone at autodesk.com
Mon Nov 20 17:54:04 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO293
Type
 Defect
Artifact ID
 FDO293 (WFS/WMS: Localize error messages)
Reported by
 Greg Boone
 gregboone (greg.boone at autodesk.com)
New artifact details:
- Component set to new value
  WMS
- Submission Reviewed set to new value
  Yes
- Description set to new value
  Steps in 3.2.x:
1. Create a FdoIConnection instance to WMS server http://cadc-brucejia.ads.autodesk.com/cgi-bin-2/mapserv.exe?map=wms/wms.map
2. Set connection parameter using the following setting.
    UserName = xxx
    Password   = xxx
3. Call method FdoIConnection::Connect().
4. An exception is thrown.
Result: Exception message is "The requested URL returned error:401".
Expected: Exception message should be simialr to "Invalid user name or password".
Steps In Map 2008:
1) Open the Data Connect UI
2) Select WMS from the list of available Feature Sources
3) Enter the URL http://cadc-brucejia.ads.autodesk.com/cgi-bin-2/mapserv.exe?map=wms/wms.map in the Specify URL or WMS Server Combo box for the valid WMS server
4) Enter in the valid username information in the dialog
5) Enter in the invalid password information in the dialog
6) Click the Connect push button in the Data Connections Dialog
7) Click the OK button
Expected results:
Error message should be presented that the username/password are invalid and a connection could not be established.
Actual results:
Failed to connect.
Failed to open FDO connection.
- Subcomponent set to new value
  FEATURE COMMANDS
- Operating system set to new value
  All
- Platform set to new value
  All
- Artifact created
- Summary set to new value
- Artifact Status set to new value
  New
- Target milestone set to new value
  3.2.0
- Priority set to new value
  P3
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
