[fdo][FDO295][New] FDO Style Sheet issue resulting in incorrect application of ...
Thomas Knoell
thomas.knoell at autodesk.com
Tue Nov 21 16:58:25 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO295
Type
Defect
Artifact ID
FDO295 (FDO Style Sheet issue resulting in incorrect application of a schema defined in a XML file)
Reported by
Thomas Knoell
thomasknoell (thomas.knoell at autodesk.com)
New artifact details:
- Summary set to new value
- Artifact Status set to new value
New
- Artifact created
- Description set to new value
The schema defined in the XML file causing the error contained geometric but no geometry property values. That triggered an incorrect setting of the geometry property value.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
