[fdo][FDO295][Modified] FDO Style Sheet issue resulting in incorrect application of ...
Thomas Knoell
thomas.knoell at autodesk.com
Tue Nov 21 17:11:33 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO295
Type:
Defect
Artifact ID:
FDO295 (FDO Style Sheet issue resulting in incorrect application of a schema defined in a XML file)
Modified by:
Thomas Knoell
thomasknoell (thomas.knoell at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO295: FDO Style Sheet issue resulting in incorrect application of a schema defined in a XML file (port to trunk)
Modified
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h?view=diff&rev=526&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r1=525&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r2=526
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt?view=diff&rev=526&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r1=525&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r2=526
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
