[fdo][FDO297][Modified] Unit Test Updates
Thomas Knoell
thomas.knoell at autodesk.com
Wed Nov 22 15:25:52 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO297
Type:
Defect
Artifact ID:
FDO297 (Unit Test Updates)
Modified by:
Thomas Knoell
thomasknoell (thomas.knoell at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO297: This updates the input and master file for a FDO unit test to reflect the intended circumstances to be tested (port to trunk).
Modified
File: trunk/Fdo/UnitTest/schema_all_v2.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all_v2.xml?view=diff&rev=529&p1=trunk/Fdo/UnitTest/schema_all_v2.xml&r1=528&p2=trunk/Fdo/UnitTest/schema_all_v2.xml&r2=529
File: trunk/Fdo/UnitTest/schema_all_v2_out_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all_v2_out_master.txt?view=diff&rev=529&p1=trunk/Fdo/UnitTest/schema_all_v2_out_master.txt&r1=528&p2=trunk/Fdo/UnitTest/schema_all_v2_out_master.txt&r2=529
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
