[fdo][FDO299][Modified] FdoIInsert rounds single values to integral values
    Brent Robinson
    brent.robinson at autodesk.com
    Thu Nov 23 13:36:15 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO299
Type:
Defect
Artifact ID:
FDO299 (FdoIInsert rounds single values to integral values)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Defect Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution Description set to new value:
fixed the formatting of single precision bind values when an FdoInsert command is executed. Previously, the values were rounded to 0 digits. The rounding is now done to 8 digits (same precision as the GenericRdbms FdoUpdate command implementation).
-- Target milestone set to new value:
3.2.1
-- Submission Reviewed set to new value:
Yes
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
