[fdo][FDO302][New] WMS: Failure selecting data from http://ceoware2.ccrs.nrcan....
    Greg Boone
    greg.boone at autodesk.com
    Thu Nov 23 14:21:42 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO302
Type
 Defect
Artifact ID
 FDO302 (WMS: Failure selecting data from http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi)
Reported by
 Greg Boone
 gregboone (greg.boone at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Subcomponent set to new value
  CONNECTIONS
- Component set to new value
  WMS
- Artifact created
- Developer Notes set to new value
  The WMS Provider does not correcly handle the default CRS:4326 as being eqivalent to EPSG:4326. When this failure happens, the WMS provider does not generate valid BBOX extents for the WMS GetMap request
- Submission Reviewed set to new value
  Yes
- Target milestone set to new value
  3.2.0
- Defect Severity set to new value
  Medium
- Priority set to new value
  P3
- Description set to new value
  After connecting to the following site, Autodesk Map doesn't display any classes.
The following WMS query is executed when selecting WMS Layer GRFM_AFR_1C:CEOWARE2
http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?&version=1%2E3%2E0&service=WMS&REQUEST=GetMap&LAYERS=GRFM%5FAFR%5F1C%3ACEOWARE2&STYLES=&CRS=CRS%3A4326&SRS=CRS%3A4326&FORMAT=image%2Fpng&TRANSPARENT=FALSE&BGCOLOR=0xFFFFFF
This results in error
CubeSERV-35000: Missing BBOX parameter (raised in function CubeservCollectBBOXInfo() of file "common.c" line 61
- Summary set to new value
- Platform set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
