[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu romica.dascalescu at autodesk.com
Mon Nov 27 11:32:22 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO170 Fixed memory leaks found with Purify in MySQL provider
Modified
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/SchemaReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/SchemaReader.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/SchemaReader.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/SchemaReader.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaElement.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaElement.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaElement.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaElement.cpp&r2=537
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp?view=diff&rev=537&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp&r1=536&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp&r2=537
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
